Zyxel Flex 100H model - How many SSL VPN licenses are included by default?
MitjaS3NEXT
MitjaS3NEXT Posts: 17 image  Freshman Member
I see that the technical limitation is 25 users. But what is the license limitation in the scenario when the Flex 100H model was bought by default (with no extra licenses like Gold pack or something else) ?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,681 image  Zyxel Employee
    Hi @MitjaS3NEXT
    This number doesn't need a license to enlarge. Also, the SSL VPN on USG FLEX H series model doesn't require license, only the SecuExtender VPN client software requires license. You may use OpenVPN to connect SSLVPN since it is a free VPN client software.
    Zyxel Melen
  • Zyxel_Melen
    Hi @MitjaS3NEXT
    Zyxel Melen
