GS1900-24EP get MAC of device connected to switch port
IronKalli
IronKalli Posts: 4 image  Freshman Member
edited February 25 in Switch
Hello everybody,
is there a way to get the MAC-address of the device which is connected to a given port of the GS1900?
I tried to filter the MAC-table of the GS1900 but it didn't show all active ports.
Thanks for any suggestions
Kalli
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @IronKalli
    Thanks for sharing the screenshot.
    May I check some details?
    1. What device is connecting on this port?
    2. Since MAC address entry has an aging time, 300 seconds, could you help to check if the device has any traffic when you can't find the MAC address on the MAC table?
    3. Can you find any MAC address for this port without filter?
    About the firmware upgrade, since the later firmware versions (after V2.80 patch 1) didn't encounter this issue, I'm unsure if the issue been fixed after firmware upgrade. You may give it a try.
    Zyxel Melen
  • XiLeiHaLo
    XiLeiHaLo Posts: 17 image  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    Use any third party SNMP tool to query your GS1900 with this standard OID .1.3.6.1.2.1.2.2.1.6, so you don't need to calculate the MAC address range by yourself.
  • Zyxel_Melen
    Hi @IronKalli
    I check my GS1900 with latest firmware version, and I can check the MAC table by all and specific port. Path: Menu > Monitor > Mac table.
    Could you share how did you filter? If possible, please record a video. Also, what's your device's firmware version?
    Zyxel Melen
  • IronKalli
    Hi
    thanks for your answer.
    My problem seems to be device related.
    It normally wokrs to see the MAC of any port as you described.
    But with some (a bit special) devices the MAC is not shown, even though the port is up
    Here is the firmware and port 9 shown
    But the MAC filter definitely does not show any entry
    I don't know what's happening here, but it is a phenomen which only shows with my special devices
    Do you think there is a firmware update I should try?
    Thanks and regards
    Kalli
  • Zyxel_Melen
    Hi @IronKalli
    Zyxel Melen
  • IronKalli
    The connecting device is a Laser Line Triangulation scanner 'scanCONTROL 2900' manufactured by company microepsilon
    And you are right again, it is related to the traffic (the scanner had no traffic for quite a long period)
    When I connect to the device and produce some traffic, I am able to see it in the MAC table of the GS1900
    It disappears after a while, but is coming back when I produce traffic again
    Sorry, I had no knowledge of the aging time
    But now I know how to handle and have everything I need
    Thanks a lot for your help
    Kalli
