IPS custom signatures
best_heygman
best_heygman Posts: 26 image  Freshman Member
Zyxel Certified Network Administrator - Security First Comment Friend Collector First Anniversary
Hello, according to the user handbook
https://download.zyxel.com/USG_FLEX_50H/user_guide/USG%20FLEX%2050H-UG.pdf
the Zyxel Flex 50H supports a maximum of 32 custom IPS signatures:
Screenshot 2026-02-24 at 19-14-52 USG FLEX 50H-UG.pdf.png Screenshot 2026-02-24 at 19-12-27 USG FLEX 50H-UG-2.pdf.png
How can I add these custom IPS signatures? I couldn't find a way in the user handbook or in the CLI guide.
  • Zyxel_Tina
    Zyxel_Tina Posts: 717 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @best_heygman,
    Thank you for your patience.
    After checking, the Zyxel USG Flex H series firewall does not support custom IPS signatures.
    The mention of "up to 32 custom IPS signatures" in the user guide was an error. We'll correct and remove this misinformation promptly.
    We regret any inconvenience and confusion this caused!
    Zyxel Tina
  • Zyxel_Tina
    Hi @best_heygman,
    Regarding your question about where to configure custom signatures: we're still confirming this and will update you once we have the information.
    We appreciate your patience!
    Zyxel Tina
  • Zyxel_Tina
    Hi @best_heygman,
    Zyxel Tina
