ZLD5.37 Patch2 and is it compatible with zyxel vpn 100?
integratedsolutions
integratedsolutions Posts: 18 image  Freshman Member
If I request the update directly from the device without uploading, will I find the version? Let me know. Thanks.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @integratedsolutions
    If your VPN 100 is running on-premise mode, then this is the latest version.
    Since it has reached its end-of-life status, I'm not sure if the device direct upgrade/cloud upgrade can find the latest version. But you can find the firmware download link via the below link.
    End of life | Zyxel Networks
    Zyxel Melen
