Firewall Configuration Converter fails with ZyWALL 110 (V4.73(AAAA.2))
Hi
Tested with two or three 110s and with all of them the converters refuses to Load the source conf. My plan is first convert to VPN100 and then from VPN100 to USG Flex 200H.
This tool:
Firewall Configuration Converter | Zyxel Networks
The error message:
"The file is mismatched with tool, please upload a ZyWALL110 (4.32 or later) configuration file."
Any ideas?
There are several ZyWALL 110s needed to replace to Flex 200Hs. Some of them have pretty complex configuration, so the plan is to stick OnPrem / Local configuration.
Hi @Rimfire
Could you share the configuration file with me? So we can help to generate the configuration file for USG FLEX 200H for you.
I will send you a private message for the configuration file.
Zyxel Melen0 -
Update:
If any user encounter the same issue, please remove the first four line of the configuration file, which leads the convertor incorrect recognize the config file.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
