A anomaly routeing rule in config for EOL VPN300
PeterUK
PeterUK Posts: 4,426 image  Guru Member
So might not be a problem I'm not sure its causing a issue and likely when I reboot this rule is not understood by the VPN300 and skips it but through I show anyway.
This is what I see in config file when I save from VPN300 for the end of routing rules
policy 129
interface vlan777
source IP192168130
dscp any
next-hop interface ge4
snat outgoing-interface
auto-disable
conn-check activate
conn-check 1.1.1.1 method icmp period 5 timeout 1 fail-tolerance 2
policy 130
interface vlan777
source IP192168130
dscp any
next-hop interface ge2
policy6 1
interface vlan1000
dscp any
  • LeoEthan
    LeoEthan Posts: 2 image  Freshman Member
    This looks like a small syntax anomaly in the config. The line policy6 1 doesn’t follow the same format as the other policies (129, 130), so it may simply be a parsing or formatting issue in the exported configuration. Since the VPN300 is already EOL, the device might just ignore that entry when loading the config. If everything is working normally, it’s probably harmless, but it might still be worth cleaning it up to keep the configuration consistent.
