New USG20W-VPN SSL VPN dropping sessions randomly and cannot determine reason?
Paluszak
Paluszak Posts: 8 image  Freshman Member
edited April 2021 in Security
I have 5 accounts (of the 5 user limit established), of which only 2 or 3 really ever connect, and hardly ever more than 2 simultaneously (quite literally)? Can someone please shed some light on this? It is usually after about 5-10 minutes and the user(s) can typically reconnect right away without issue. I cannot find ANY time-outs or the like anywhere? What might I be missing?
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    Hi @Paluszak
    It’s recommended to upgrade your firmware to the 4.33wk19 first.
    And you can go to Monitor > Log to check SSL VPN log during client establishing fail to get more information regarding to your symptom.
  • warwickt
    warwickt Posts: 111 image  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Hi @Paluszak
    The logs are very helpful.... just to add...
    L2TP clients disconnecting as well?.... I might add as well assuming the connection are L2TP VPN clients??.
    Try (and or these) in the L2TP VPN Gateway for the (Phase 1 Settings) through CLI or WEB UI
    • disabling DPD (Dead Peer Connection) and or
    no dpd
    • changing the DPD period.
    dpd-interval nn seconds
    In this actual example, the L2TP VPN Gateway at has its DPD disabled.
    Router> show isakmp policy yeun_long_site3_L2TP_gateway
    ISAKMP policy: yeun_long_site3_L2TP_gateway
      IKD_ID: 5
      negotiation mode: main
      proposal: 1
      encryption: 3des
      authentication: sha
      SA lifetime: 3600
      key group: group2
      NAT traversal: yes
      dead peer detection: no
    ..... snip
    ..... snip
      allowed auth method: mschapv2
      username:
      password:
      VPN connection:yeun_long_site3_L2TP_connection
      vcp reference count: 0
      IKE_version: IKEv1
      active: yes
    Router>
    Worth a look,
    HTH
    Warwickt
    Hong Kong
  • Paluszak
    Thank you so much. I have looked at the logs but I cannot trace it back to anything definite, plus they are are difficult to understand frankly.
    I currently have them setup using ONLY the SSL VPN.
    I will review your suggestions and thank you kindly again!
    Jason
  • Paluszak
    ZyXel_Stanley
    I assume that Release V4.33wk19 is newer than V4.33(ABAR.0)C0. I currently have release V4.33wk19.
    Still working on reviewing logs with customer. Has been hard to coordinate but I will be doing soon!
    Thank you!
    Jason
  • Zyxel_Stanley
    Hi @Paluszak
    Yes, 4.33WK19 is newer than 4.33C0 firmware.
  • Paluszak
    This is the ONLY log entries that are shown when someone gets disco'd...
    40
    2019-06-25 08:25:10
    info
    SSL VPN
    Account: Darcy
    network extention has been accessed. sent=256659 rcvd=205365
    41
    2019-06-25 08:25:10
    info
    SSL VPN
    64.53.192.11
    192.168.200.100
    Account: Darcy
    SSL tunnel has been disconnected
  • Zyxel_Stanley
    Hi @Paluszak
    Can you take screenshot in Monitor > Log during SSL VPN client connecting fail?(do not filter category)
    Maybe it will have disconnect reason.
