Remote vpn ipsec, access Lan behind site to site Firewall
I have a remote IKEv2 ipsec dynamic access to firewall 1 and want to access lan behind firewall 2 that is setup for site to site between Firewall 1 Firewall 2.
How should i set up routing and security policy to get it to work?
Firewall 1, USG Flex 100 Lan1 ip 192.168.101.1
Firewall 2, USG Flex 200 Lan1 ip 192.168.100.1
Tony
Might help to get a layout you can use my site to draw out the network you have.
Network Testing Tools | Port Scanner, VPN Tests & DNS Lookup
but from what I can tell you have a site to site between Firewall 1 Firewall 2 with the given local and remote policy so you will need.
on firewall 1
incoming Tunnel and the remote IKEv2
Destination address 192.168.100.0/24
next hop VPN Tunnel and the Tunnel to firewall 2
on firewall 2
incoming LAN of 192.168.100.0/24
Destination address the remote IKEv2 IP pool
next hop VPN Tunnel and the Tunnel to firewall 1
then
security policy to allow the traffic
Hi @ITB_Tony,
To allow your remote IKEv2 VPN clients on Firewall 1 to access the LAN behind Firewall 2, you can treat Firewall 1 as a hub and route the traffic from the remote VPN clients into the existing Site-to-Site VPN tunnel.
Please check the following settings:
- VPN Phase 2
- If you are using a policy-based VPN, both firewalls need to include the Remote VPN Client IP pool in the Phase 2 settings.
- On Firewall 1, add the VPN client IP pool to the Local Policy in addition to 192.168.101.0/24.
- On Firewall 2, add the VPN client IP pool to the Remote Policy.
- Policy Routes
- To define how traffic is forwarded between the two VPN tunnels, please configure
- On Firewall 1
- Incoming: Remote Access VPN tunnel
- Source: VPN Client IP Pool
- Destination: 192.168.100.0/24
- Next-Hop: Site-to-Site VPN tunnel (to Firewall 2)
- On Firewall 2
- Incoming: LAN
- Source: 192.168.100.0/24
- Destination: VPN Client IP Pool
- Next-Hop: Site-to-Site VPN tunnel (to Firewall 1)
- On Firewall 1
- Security Policies
- Make sure the firewall rules allow this traffic.
- On Firewall 1 - Allow traffic from IPSec_VPN (Remote VPN clients) to IPSec_VPN (Site-to-Site), with destination 192.168.100.0/24.
- On Firewall 2 - Allow traffic from IPSec_VPN (VPN client pool) to LAN (192.168.100.0/24).
Zyxel Tina
0 - VPN Phase 2
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
