IP Source Guard Static Binding Many IP to one MAC
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited July 2024 in Switch Ideas
Currently with IP Source Guard Static Binding you can only add one IP to one MAC but what if you have many IP's to one MAC.
1 votes
Active · Last Updated
  • Zyxel_Albert
    Zyxel_Albert Posts: 36 image  Zyxel Employee
    First Answer First Comment Friend Collector Third Anniversary
    Hi @PeterUK
    Welcome to Zyxel community!
    We've heard your voice. Could you please share us your application. In what circumstances would many IPs map to one MAC address?
    Thanks for your sharing and we are looking for your feedback.
    Sincerely,
    Zyxel_Albert
    edited June 2019
    I have this setup
    https://businessforum.zyxel.com/discussion/comment/8229/#Comment_8229
    and would like to have IP Source Guard with ARP Inspection on my GS2210-24 problem is I have two PC's with many static IP's to one MAC and the GS2210-24 can't map many Ips to one MAC address.
  • Zyxel_Albert
    Hi @PeterUK
    Appreciate your sharing and I can understand why you need to bind multiple IPs to one MAC now. But I'm curious about why the PCs have multiple IPs. Are the IPs used in the same time or they just change the IP from time to time? What I can imagine is the PCs are running VM, aren't they?
    We are looking forward to hearing from you.
    Sincerely
    Zyxel_Albert
    I have custom bind setup between the PC's with like query-source address 192.168.255.56 port *; so that the other PC sees the other IP in ACL to do the query request.
  • Zyxel_Albert
    Hi @PeterUK
    Thank you for your sharing. We will evaluate your requirement and transfer this post to idea to see if there are more people need such enhancement. It could help us on the judgement.
    Thank you
