Problem with UI with GS1200-5HP v2
124»
  • I'm also experiencing this issue on the latest version of the GS1200-HP5 V2 (C3). Requests to the web UI randomly fail with an empty response. I'm experiencing this issue with all browsers as well as when I'm using curl from the command line. The switch is connected directly to the PC executing the request.
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hello @firepinn
    To help us investigate further, could you please provide a video recording of the error as it occurs across different browsers, including Safari?
    Nami
  • adron
    adron Posts: 2 image  Freshman Member
    I too am experiencing this issue. It is very disruptive to my use of the switch. I need to be able to log in and disable and enable ports, but every other page load or submission errors out. Seemingly random requests (pages/scripts/images) fail to load with 0 bytes returned. I use primarily use Edge as my browser.
    I see that this issue was raised more than 2 years ago. Is there an official solution yet? Do you need additional data?
    Here are some reloads:
    when logged in:
    As you can see, the switch fails to respond to random files, and this causes serious errors in the UI.
  • XiLeiHaLo
    XiLeiHaLo Posts: 17 image  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    Windows?
    Try Ctrl + F5 or private browsing mode?
