Is there a way to configure QOS for Skype on USG 110
adi_dragnic
adi_dragnic Posts: 15 image  Freshman Member
edited April 2021 in Security
Hi all,
Is it possible to configure Qos for Skype because we are experiencing some problems with quality of calls ?
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    Hi @adi_dragnic
    Unless it is an internal network issue, any QoS configuration will be removed by your ISP provider.
    Skype and other video calling software can be limited or completely blocked in some countries.
    Regards
  • Zyxel_Stanley
    Hi @adi_dragnic
    You can setup BWM with highest priority for Skype.
    (1)  Go to Configurtion >Object > Application Click button to add Skype services in Application object.
    (2)  Go to Configuration > BWM Click Add button create a rule
    Select Skype object which added in step(1) and set inbound/outbound priority as 1.
    After enabled BWM function, then Skype service will forward by USG with highest priority.
