XGS1250-12 Switch port 11 not working?
Metalix
Metalix Posts: 3 image  Freshman Member
Hello I've got this switch (XGS1250-12) and over time I've noticed that port 11 is not working. The remaining 10 ports do work with 1GbE and port 9/10 is able to do 2.5/10GbE as expected. I've not tested port 12 SFP+ as I don't use it.
Currently on latest firmware V2.00(ABWE.1)C0
Can verfiy eco mode is disabled.
Is this a hardware fault or is there something else I can try?
See attached screenshot where I connected each port breifly to validate a connection.
