New USG20W-VPN SSL VPN dropping sessions randomly and cannot determine reason?
I have 5 accounts (of the 5 user limit established), of which only 2 or 3 really ever connect, and hardly ever more than 2 simultaneously (quite literally)? Can someone please shed some light on this? It is usually after about 5-10 minutes and the user(s) can typically reconnect right away without issue. I cannot find ANY time-outs or the like anywhere? What might I be missing?
Hi @Paluszak
It’s recommended to upgrade your firmware to the 4.33wk19 first.
And you can go to Monitor > Log to check SSL VPN log during client establishing fail to get more information regarding to your symptom.
Hi @Paluszak
The logs are very helpful.... just to add...
L2TP clients disconnecting as well?.... I might add as well assuming the connection are L2TP VPN clients??.
Try (and or these) in the L2TP VPN Gateway for the (Phase 1 Settings) through CLI or WEB UI
- disabling DPD (Dead Peer Connection) and or
no dpd
- changing the DPD period.
dpd-interval nn seconds
In this actual example, the L2TP VPN Gateway at has its DPD disabled.
Router> show isakmp policy yeun_long_site3_L2TP_gateway ISAKMP policy: yeun_long_site3_L2TP_gateway IKD_ID: 5 negotiation mode: main proposal: 1 encryption: 3des authentication: sha SA lifetime: 3600 key group: group2 NAT traversal: yes dead peer detection: no ................ ..... snip ..... snip ................ allowed auth method: mschapv2 username: auth method: mschapv2 password: VPN connection:yeun_long_site3_L2TP_connection vcp reference count: 0 IKE_version: IKEv1 active: yes Router>
Worth a look,
HTH
Warwickt
Hong Kong
Thank you so much. I have looked at the logs but I cannot trace it back to anything definite, plus they are are difficult to understand frankly.
I currently have them setup using ONLY the SSL VPN.
I will review your suggestions and thank you kindly again!
Jason
ZyXel_Stanley
I assume that Release V4.33wk19 is newer than V4.33(ABAR.0)C0. I currently have release V4.33wk19.
Still working on reviewing logs with customer. Has been hard to coordinate but I will be doing soon!
Thank you!
Jason
Hi @Paluszak
Yes, 4.33WK19 is newer than 4.33C0 firmware.
This is the ONLY log entries that are shown when someone gets disco'd...
40
2019-06-25 08:25:10
info
SSL VPN
Account: Darcy
network extention has been accessed. sent=256659 rcvd=205365
41
2019-06-25 08:25:10
info
SSL VPN
64.53.192.11
192.168.200.100
Account: Darcy
SSL tunnel has been disconnected
Hi @Paluszak
Can you take screenshot in Monitor > Log during SSL VPN client connecting fail?(do not filter category)
Maybe it will have disconnect reason.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
