[USG Flex H] - How to resolve external FQDN to internal Hostname/IP
Hello everyone,
I try to achieve myself this question using the DNS settings, but without any success.
My goal is to internally resolve an external FQDN site with an internal hostname/IP.
For example I would like to resolve the FQDN "www.google.com" AS 192.168.0.1. In Windows, this can be achieve modifying the hosts file, but if I would like to find a solution for every devices into my local network?
Thank you so much
Oh wow… after some tries I've found a solution.
DNS Settings → A record:
Hostname: *
Domain: google.com
IP: 192.168.0.1Sounds good… thank you
Hostname: *
Domain: google.com
Just beware of some caveats depending on your configuration.
- Some clients (e.g. Chrome) might use DoH/DNS override.
- If DNS recursion is used by a client downstream your gateway, you would also have not expected result.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 627 USG FLEX H Series
- 352 Security Ideas
- 54 Wireless Ideas
- 492 News and Release
- 108 Security Highlight
