FLEX 700H services
Good day,
Have a question if there are any plans to add functionality:
- SSL VPN certificate based authentication. Login/Pass as the only method looks really insecure.
- In NXC2500 (wifi controller) it was a nice feature to generate guest logins on the fly. Is it something similar feasible/planned in 700h?
Thank you
The FLEX 700H does use a generated certificate that is in the config file but does not look like you can use your own.
If needed you can generated new certificate in advanced settings on SSL VPN page.
Hi @hORnZ
Currently H series doesn't support certificate based authentication. I will create an idea post to monitor its comments and votes to evaluate. idea post
About the WiFi controller function, may I know which function did you mean? I'm unsure which function matches your description. Please help to share more details with us, thanks.
Zyxel Melen0 -
Sorry, but this has almost nothing to do with clients certificates based authentication. FLEX own cert in SSL VPN is used to build TLS handshake within control channel part. However, lack of using custom CA/PKI is indeed a limiting factor too.
@Zyxel_Melen is it possible to get a feedback? Thank you.
- 245 Nebula Ideas
- 6.9K Security
- 813 USG FLEX H Series
- 393 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 543 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 125 Security Highlight
