Link-sticking, double wan configuration, firmware 4.30
Always on.0
you don't need to enable it manually, just enabled in default0
In firmware 4.33, the link-sticking does not work or does not work correctly!
No traffic through one interface
Hi @Grant
The link sticking function is to stick the session on one of WAN interface when destination address is the same until the session expires.
V4.31(AAAC.1)ITS-WK52-r86652 is working correctly! I have a uniform load on the adaptersю
Hi @Grant
Link sticking will keep traffic working on same WAN interface when destination is the same one.
It can prevent some of secure WebSite(Bank) those will check source IP address per session. If IP address changed, then will deny the session.
So link sticking function is required.
According to your scenario ge1 loading is higher than ge2. The reason should come from many sessions connecting to same server.
Before sessions expired from USG these sessions will always pass through by ge1.
Wrr algoritm dont work!
The second wan is not used!
On firmware 4.31 everything worked fine. Rx / TX on both adapters was about the same!
My old gateway works better than new!
Hi @Grant
The firmware for better balancing algorithm is ready. I will send you firmware by private message.
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
