A question about the port security setting
Hi @KinGsman,
Welcome to Zyxel community!
The reason why you have this issue is the MAC address of GS2210 will be also learned in the MAC table of XGS4600.
You may access CLI and use "show mac address-table port X".
Or, access WebGUI and see the MAC table if there are already 20 MAC addresses and the MAC address of GS2210 is included before you change the limit number to 21.
Hope it helps.Jason1 -
Hi Jason,
Thanks for your reply!
Now I know the reason! How can I forget GS2210!?
After checking the MAC table, I found that the MAC of GS2210 is really on the MAC table.
Thanks for help!!0 -
Interesting topic. I've learned early on to always trust the MAC address table.
Hi
I will buy a Handfull GS2210 and will use Port Security to.
Cisco offer a nice feature when a unknown device is plugin the switch put that device in an guest Vlan.
Can the GS2210 Series to? With the Zyxel iStacking can I config Vlans, Port Security in one?
1.
Guest VLAN is a feature can be combined with 802.1x port authentication.
GS2210 can support it, please see attachment for some detailed info.
2.
Yes, you can config both VLAN and Port security in iStacking.
Zyxel_Lucious
Thanks with iStacking I can configure (at least the most important) function of all 2210 at once?
Like Vlan, Port Security think? (Like when mac adr., client,... plug in a Ethernet cable than put it into Vlan ID X)?
Is there anythink (common) who could NOT be configured) in a mass via iStacking or is there anythink I should know before I buy it?
I will soon start a now post with my own question about the Switch.
The iStacking feature is to allow you access other member's configuration in manager's web-GUI (see image below), the configurations of members are still individual.
As for what can be configured in iStacking, please see image in my previous reply.
Zyxel_Lucious
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
