Zywall 310 allow only one IP public FTP port
steve15f
steve15f Posts: 16 image  Freshman Member
edited April 2021 in Security
Hi dear,
i wanted to know if it's possible to open the FTP port (21) for only one external IP ?
thanks
    PeterUK Posts: 4,448 image  Guru Member
    Why yes just setup the firewall to allow one source IP when you setup a address object for host of the IP.
  • steve15f
    edited June 2019
    thanks for your reply
    i'm trying to allow FTP from external users but it's not working, can you help me ?
    you can see attach the policy control and NTP rule ...
    FTP TCP port 21
    i've an error on the connection :
    Statut : Connexion à x.x.x.x:21...
    Statut : Connexion établie, attente du message d'accueil...
    Statut : Serveur non sécurisé, celui-ci ne supporte pas FTP sur TLS.
    Commande : USER FTP-User
    Réponse : 331 Password required for User
    Commande : PASS ********************
    Réponse : 530 Login incorrect.
    Erreur : Erreur critique : Impossible d'établir une connexion au serveur
    For information ,with the Same rule (but with port 22) it's working in SFTP (SSH FTP)
    it's a FTP on a synology
    ty
    Do you have ALG for FTP enabled with FTP transformations?
    Your FTP logs show Login incorrect so traffic is getting to the FTP server.
  • steve15f
    Hi PeterUK
    thanks for your reply but i'm sorry i don't know about ALG, what is it and where can i show this ? thanks
    Its in the Zywall 310
    Network > ALG
    it allow the FTP traffic to work for other ports the FTP needs.
    It might not help as your getting Login incorrect so check your user name and password.
