Nat rule with multiple public address
Hi, i tried to configure a nat rule using another public IP but without success on a USG1100
First i've created a virtual interface Wan 1:1 with another public ip address of my subnet, i've created the nat rule with this public ip as source ip and WAN1 as incoming interface (if i select WAN1:1 i've got a cli command error), then i've created the right rule in the policy control screen but the port 'ive selected remains closed. The same rule created with the primary ip address works well.
What's the problem in my configuration?
Thank You
I think you don't need virtual interface just in NAT rule for Incoming interface = wan1 and Original/External IP = your other public IP.
Can you check with packet capture for host IP your other public IP that packets are coming in
@nesh
The method PeterUK suggested is similar to the following KB.
Hope it helps.
http://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=016415&lang=EN
Hi @nesh
There is no need to create virtual interface Wan1:x for 2nd IP port mapping. Just create virtual server/NAT rule and firewall rule.
You can disable the firewall rule temporarily to troubleshoot this issue. If it works after firewall rule disable, the port forwarding settings is correct,
you can go straightly to check the firewall rule.
CLI disable firewall rule:
Router(config)# no firewall activate
You can also reference this article: https://businessforum.zyxel.com/discussion/1324/how-to-route-multiple-public-static-ips-with-zyxel
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
