Setup WAN Port to 1000MB
MarcelG
MarcelG Posts: 25 image  Freshman Member
edited April 2021 in Security
we have to set the speed of the WAN Port 1 on 1000 MB / sec and Full Duplex
With autonegotiation we have problems with streaming services on Internet an have to fix the speed to 1000 MB/s (1GB)
Via PuTTY cosole we can set the speed only to 10 oder 100, but not 1000 ?
Is there possible to fix the speed to 1000, and why ?
    PeterUK Posts: 4,400 image  Guru Member
    Auto should work fine to run at 1000Mb if link is dropping to 100Mb your cable might be bad.
  • MarcelG
    The cable between router and Firewall is new, 0.5m and all my patchcables are cat.6a
    The provider ask me to fix to 1000mb (not auto) because auto could be disturbing using with streaming services
    the problems in my network are with differents equipments like PC, Laptops an apple devices
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    Previously I got the same problem and I reported the issue to Zyxel support.
    They give me the date firmware which supports fix speed 1000.
    Here are the commands for your reference.
    P.S. I'm using ZyWALL 110 with firmware 4.33(AAAA.0)ITS-WK19-r88384
  • MarcelG
    My FW is: V4.33(AAKY.0) / 2019-01-09 17:34:25
  • MarcelG
    but with this FW speed 1000 is not possible
  • Zyxel_Cooldia
    edited July 2019
    Hi @MarcelG
    Here is the firmware download link, ftp://ftp2.zyxel.com/USG60/firmware/433AAKY0ITS-WK19-r88384.zip
    Please have a check.
