BPDU - GS1910-24HP
I have config a vlan to other cisco switch, the cisco switch disable the port because bpdu was sending to their switch from my gs1910-24hp.
This is answer from their network team:
I can see that the BPDU protection kicked in. Pls ask the vendor if they can configure their switch to stop advertise BPDU packets to our network. We have this filter to protect us from unwanted topology changes.
How can i that to the specific vlan port.
Hi @Patricki
Welcome to Zyxel community!
To stop sending BPDU packet you have to disable spanning tree, please go to "Configuration -> Spanning Tree -> STP CIST Port Configuration" to make adjustment.
Hopefully this is what you seek.
Zyxel_Lucious
5
Hi @Patricki
Zyxel_Lucious
5 -
thanks for your fast answer.
it worked really Good.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
