[Coins program] - Same reason, different accreditation
Hello everyone,
I see now that between the end of the 2025 and starting 2026, the accreditation coins for Post/Comment created passed from 4 coins end 2025 to 2 coins starting 2026.
Is this correct? There is a reason to pass from 4 to 2?
Also for "Like Received", pass from 2 to 1.
Thank you
Hi @Maverick87 & @PeterUK
The bonus was started between Aug 12 – Oct 31, 2025 | Limited Time Only. You can check the below link:
🎉Turn Your Community Points into Real Rewards🎉 — Zyxel Community
Zyxel Melen1
I think at the start of the Coins program it was double Coins for a limited time but you never know that might happen again.
Zyxel Melen1 -
Thank you @Zyxel_Melen
- 243 Nebula Ideas
- 6.8K Security
- 782 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
