[USG Flex H - V1.39(ABZH.0)ITS-260800686] - User Custom DDNS effective IP not appear
Yes but for Dynu there isn't any effective IP listed. So I think it's a visual bug.
I think your missing the obvious the way you have done Dynu is by custom which has auto but the pre set No-IP has no auto
And this is clear… but…
1: Why for the custom entry there isn't "Interface" as IP Address
2: What changes between the two types for the effective IP? The only thing can be that the effective IP is "calculated" throught a "return" call from the service and for the custom service, is unknown (also if can be implemented a field for return, so can be called after the update, if the service have it)
Well I don't know why there is no Interface option for custom.
The way DDNS works for auto is it never knows what IP to send to the DDNS server it just say hello can you see what IP I'm from and use that thanks and if the interface IP changes DDNS is triggered again. Thats all I know about auto.
If you want to see effective IP you can use Public IP option which I think I had a hand in Zyxel doing.
Hi Peter,
After change the WAN IP, now seems that the effective IP is showed into the table without touch the configuration, just renewed the WAN IP.
But…
Seems there is a failure on User custom when I click on "Update" button… for the No-Ip, after the update, the IP under "Effective IP" return valid, instead for the "User custom" not (it's blank).
@Zyxel_Melen , @Zyxel_Judy, @Zyxel_Luna can you check this problem?
Thank you
So I relooked at this as dynu still supports http for DDNS so you can see whats happening
GET /nic/update?hostname=Zyxel-DDNS-test.freeddns.org HTTP/1.0
Authorization: Basic =
User-Agent: ZyWALL/1.0
Host: apiserver.dynu.com HTTP/1.1 200 OK
Date: Sun, 16 Aug 2026 13:6:38 GMT
Server: Dynu Web Server
X-Powered-By: Dynu Dynamic DNS Service
Content-Length: 17
Content-Type: text/html; charset=UTF-8
Connection: close good 92.239.74.95So there is return of what IP dynu sees and effective IP shows but then if you update again see
Date: Sun, 16 Aug 2026 13:9:46 GMT
Content-Length: 5
Connection: close nochgwhich causes Flex to show no effective IP
Hi Peter,
so you tell me that Dynu don't update the IP if the current IP is the same that have already? And in this context the IP return is empty because Dynu not have updated the IP?
Probably can be this the problem…
yes looks that way if Dynu sends back nochg this means your IP is the same it saw last time by Dynu but then because nochg is not a IP this looks to make the effective IP not show anything.
Hi @Maverick87 @PeterUK @kelmi ,
Thank you for your discussion and analysis.
Because Dynu DDNS has its own specific DNS update mechanism, it is not fully compatible with our [User Custom] mode. In the upcoming firmware release, we will update and fix the issues related to the [Dynu Basic] mode. By then, you will be able to switch to [Dynu Basic] for better compatibility.
Thank you very much for your patience and continued support.
Hi @Zyxel_Luna,
Thank you for your help.
Two things:
- Also when the IP is real refreshed, the field still remaining empty;
- Can you share the beta firmware when the issue is fixed?
Thank you
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
