Firmware 1.39 - secondary WAN IP
As said in another post, this firmware is worst than a beta…I'm happy I'm with the 1.38
Anyways to revert back to 1.38? I try update by uploading older firmware, but it doesnt work.
you can enable the gui system standby-firmware-display true to show both firmware slot to reboot to the standby that should have V1.38
USG FLEX H Series - Firmware Management Enhancement — Zyxel Community
I had display the standby firmware, both is 1.39.
Odd normally only one would change.
Try getting V1.38 firmware and upload to the standby slot it should upload
you can get V1.38 here
I have revert back to 1.38 successfully. Thank you.
Hallo,
i have not yet updated to 1.39 and want to know when a fix will be available.
I have exactly the same scenario so problems are expected when i upgrade.thx.
Hallo,
is there any statement when there will be a Patched Firmware or so which resolves the already complained problems for 1.39?
I have not yet updated because of this special problems which would pop up, but i have to plan for doing updates in our offices.
Some approx. timeframe would be good to know.Thx.
Hi @Venta
Sorry for the delay since we took some time to confirm the information.
We won't release another patch for the fix, and I will send you a private message for the weekly firmware download link. Please help to check the private message.
Zyxel Melen0 -
Hi, can you send us the link to? We have the same problem with the newly setup USG Flex 200 HP with the latest 1.39 Firmware…
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
