[Alert] Network-Firewall-----AP Disconnect
  • Tattoofreak
    Tattoofreak Posts: 10 image  Freshman Member
    Zyxel_Vic said:
    Hi @Tattoofreak
    Sent in private message
    Thank you, the patch did the trick.
  • mizzomizzo
    mizzomizzo Posts: 2 image  Freshman Member
    I am having the same issue on USG20W-VPN firmware 4.33. Please share the patch! thanks
  • Zyxel_Cooldia
    Hi @mizzomizzo
    Here is the firmware download link,
    ftp://ftp2.zyxel.com/USG20W-VPN/firmware/433ABAR0ITS-WK19-r88384.zip
  • mizzomizzo
    thanks 😁
  • Arnaud
    Arnaud Posts: 4 image  Freshman Member
    I have the same problem with a USG40W.
    I see on the FTP two firmwares that look like the one you're talking about for the USG20VPN, here:
    • ftp://ftp2.zyxel.com/USG40W/firmware/433AALB0ITS-WK12-r87753.zip
    • ftp://ftp2.zyxel.com/USG40W/firmware/433AALB0ITS-WK19-r88384.zip
    can I apply either to solve the problem, and wich one ?
    (exactly the same problem: AP Disconnect. MAC:xx:xx:xx:xx:xx,Name:Local-AP,Reason:Idle in RUN State,Model:USG40W)
  • Arnaud
    i've had the answer in private message, didn't saw.
    i'm applying ftp://ftp2.zyxel.com/USG40W/firmware/433AALB0ITS-WK19-r88384.zip
    i'll post result.
    i m very perplexe that french support team know this problem for me since at least 4 years .... and the only answer was : reboot device, it's not intended to run 24/7 .....
  • Tattoofreak
    Is this issue resolved with firmware 4.35? Can I upgrade without being concerned to fall into the samie issue again?
  • Tattoofreak
    @Zyxel_Cooldia Is this issue resolved with firmware 4.35? Can I upgrade without being concerned to fall into the samie issue again?
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,461 image  Zyxel Employee
    Hi @Tattoofreak,
    The fix for Built-in access point (local AP) and internal AP disconnect issues are merged to 4.35.
  • Tattoofreak
    Hi @Tattoofreak,
    Thank you!
