[USG Flex H - V1.39(ABZH.0)ITS-260800686] - User Custom DDNS effective IP not appear
  • Maverick87
    Maverick87 Posts: 427 image  Master Member
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
    You're right.
    Request submitted
  • Maverick87
    Hello @PeterUK and @Zyxel_Luna,
    after opened the ticket on Dynu, this is the reply:
    We understand that your interface is discarding the 'nochg' response, which causes your "Effective IP" field to blank out when the IP address hasn't changed.
    The response behavior you're seeing follows the standard Dynamic DNS update protocol. The Dynu API returns:
    - good <IP> only when the IP address has actually changed and a successful update was performed.
    - nochg when the IP address is unchanged, meaning no update was performed.
    This design has been in place for many years to align with long-standing DDNS specifications and to ensure efficient API usage. Changing this behavior to always return good <IP> would break compatibility with countless existing routers, devices, and scripts that rely on this standard response format, so we are unable to make that change.
    Recommended Workaround:
    Your interface should handle the nochg response by retaining the last known IP address rather than clearing the field. If your "Effective IP" field must always show the current registered IP, you can either:
    1. Modify your interface to keep the previously stored value when nochg is received.
    2. Query a separate status endpoint (if available) to fetch the current IP without triggering an unnecessary update.
    So seems that the "nochg" response is a DDNS API Standard response, also if I see that other DDNS services, for the nochg return also the IP (nochg 1.2.3.4).
    Anyway, is possible to "save" the effective IP before the update? Then, if the update return "nochg" status, into the effective IP put the previous saved IP.
  • Zyxel_Luna
    Zyxel_Luna Posts: 80 image  Zyxel Employee
    edited August 26
    Hi @Maverick87 ,
    From your screenshot, we noticed that you are currently using the [Auto].
    Based on our testing, the Effective IP does not display under [User Custom] mode, as this mode is not specifically designed for the Dynu DDNS mechanism.
    However, under [Dynu Basic] mode, the Effective IP displays properly regardless of selecting Interface or Public IP.
    We will release a new weekly firmware next week.
    After upgrading, you will be able to use [Dynu Basic] mode normally, and the Effective IP will be displayed correctly.
    Thank you for your patience and understanding.
  • Maverick87
    Hi @Zyxel_Luna,
    Thank you for your reply, but I think is necessary implement a sort of "backup" if the nochg message arrive without the IP.
    Anyway, I'll wait the weekly firmware. If you receive the fix, can you tell me so you pass me the weekly firmware?
    Thank you
  • Maverick87
    Hi @Zyxel_Luna, @PeterUK,
    with the last weekly firmware provided by Luna today, I was able to modify the Dynu DDNS to DynuBasic, and now seems to work also the Effective IP.
    So passed from DDNS Type "User custom":
    To "Dynu Basic":
    Thank you
    PeterUK Posts: 4,718 image  Guru Member
    but thats from interface not auto @Maverick87
  • Maverick87
    edited August 27
    Hi @PeterUK,
    How can I try the auto interface?
    You can't you have to use user custom which is what you was thinking was a issue.
  • Maverick87
    Yes exactly
    So your now not got to test if user custom for Dynu is fixed for auto.
