Cannot remote manage USG20W-VPN after establishing SecuExtender connection
Problem solved. Answer was “none of the Above”. come to find out, there were some residuals around 2-factor authentication. Even though I had unchecked “enable”, it was still trying to auth, until I went back in and unchecked all the other boxes. FWIW, the IP schema is correct, and there was no need to change global settings.
Thanks for all the help tho!
That’s weird, it was caused by 2 factor even you didn’t enable that.
Could you send me your configuration file via private message.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
