Extremely slow communication between LAN1 and LAN2 on the USG60
pieroCastampi
pieroCastampi Posts: 53
image  Ally Member
Traffic between LAN1 and LAN2 is extremely slow. I am not sure if replacing the USG with a more modern device would solve the issue. So, I was considering a Layer 3 switch to handle the traffic between the two LANs. Is this a viable solution? And if so, could you recommend a suitable product?
    PeterUK Posts: 4,835
    image  Guru Member
    Maybe a bad cable limiting you to NIC speed of 100Mb
    check your switches and device are 1Gb
    image  Guru Member
    edited September 29
    Yes the USG60 may be at a hardware limit to do the routing a Layer 3 switch setup up correctly with the USG60 can off load the traffic to go by the switch.
    something like a XS1935-10 or XGS2220-30
  • pieroCastampi
    image  Ally Member
    Ok, grazie
  • pieroCastampi
    image  Ally Member
    Good morning. I don't know if it's possible to reopen this discussion, but I would like to report that even after replacing the USG60 with the USG FLEX 200H model, the speed—consistently measured using OpenSpeedTest—does not exceed 90 Mbps. How can I increase that speed? Thank you.
    image  Guru Member
  • pieroCastampi
    image  Ally Member
    Good evening, all the switches are 1Gb, as are the PC NICs. Anyway, I did this test. I connected a PC directly to a LAN1 port and tried running a speed test, again using OpenSpeedTest, to a brand-new server on LAN2 (it's the only one on LAN2). Unfortunately, even with this, the speed doesn't exceed 100m.
    image  Guru Member
    What link speed does windows say your running at?
  • pieroCastampi
    image  Ally Member
    I apologize for wasting your time. You were right, there was an old switch forgotten in a corner that was operating at 100Mbps. These things sometimes happen when multiple people are working on network devices. So, problem solved. Thanks again for your attention.
