BIG BAD Throughput issue!
PeterUK
PeterUK Posts: 4,835
image  Guru Member
edited August 25 in USG FLEX H Series
USG FLEX 200H V1.39(ABWV.0)
I had a bad bad feeling when I went to test this...and my feeling was sadly right! And on top of that I think I know whats in ZLD was added to uOS to cause this and I hope I'm wrong!
So here is the simple test local HTTP server download a file by Edge over a two 2.5Gb ports in a bridge.
Let me start with showing the V1.39 Throughput you might think 1.2Gb is pretty good for a bridge
and 1.9Gb for SNAT ok
and now V1.38(ABWV.0)ITS-26WK16-m11228 for just the bridge thats a jump!
So what do I think is unfortunately causing this? Forward path out a given interface to reverse path in to another interface. In short before V1.38 there was a setup I did for ZLD that could not be done by uOS then V1.39 happens and I found I could and I hope I'm wrong as to the added support caused this.
«1
  • Maverick87
    Maverick87 Posts: 544
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
    image  Guru Member
    edited August 25
    Hi Peter,
    so also my speedtest problem is valid.
    Do you think it's the same issue? I could also revert the configuration to 1.38, but unfortunately I'm not at home today.
    What could be causing this problem? It's interesting, because if I can still get 2.5GB with the bridge, it would have solved a lot of problems with different subnets.
    I also tried to disable all the IPS/Security for not overload the CPU but the problem still present.
    I've notice that when I try the speedtest, the CPU Load raise up to 50/55%, causing full load (exactly 100%) on CPU3 & CPU4 (I think are the fast-path CPUs), instead CPU1 & CPU2 are irrilevant (5/10%), for both download and upload tests.
    image  Guru Member
    Just to update I have retest with V1.40 for bridge performance and its now running at full speed.😎
  • Maverick87
    image  Guru Member
    Hi @PeterUK
    Interesting… so I need to test it when I've more time :D
  • Maverick87
    image  Guru Member
    edited October 30
    Hello @PeterUK,
    I've updated my 500H to the new 1.40 and tried the bridge configuration between P2 and P3-P12 and seems that the speed is the same between the bridge configuration and the single interfaces.
    I've a 2.5Gbit NAS (the console) and a PC connected with 2.5Gbit docking station and this is the result:
    • P2 without bridge: image.png image.png
    • P4 without bridge: image.png image.png
    • P2 + P3-P12 in a bridge: image.png image.png
    So seems that now with or without the bridge, all works at the same speed
    image  Guru Member
    edited October 31
    Seem odd you not maxing out on speed given I tested on FLEX 200H vs your 500H you should do the test as I did two PC with 2.5Gb or better with a web server with a big file and download on the other.
    Did you test with BWM off?
    The NIC I used in testing was Intel I225-V
    One thing it might be if the FLEX H does this is dynamically changes the send and receive buffer? and is not upping the size in your case?
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,284
    image  Zyxel Employee
    This might due to security services.
    Hi @Maverick87, please try to disable "Anti-Malware", "IPS", "content filter" and check again. These security services will check the traffic, which could cause lower throughtput than expected.
    Zyxel Melen
  • Maverick87
    image  Guru Member
    edited November 2
    Hi @Zyxel_Melen,
    seems that there isn't any difference disabling the security services.
    The result of 06:01PM are with IPS, Content Filter and Anti-Malware enabled;
    The result of 06:03PM are without IPS, Content Filter and Anti-Malware.
    So seems that there isn't any difference.
    Melen, remember that I've changed the Flex 500H because a port was dead on the previous flex; I've opened an RMA and I've changed device. Now, this new flex is still without any registration/license. Also if I've enabled the services, without any license, I think that not working. Can you confirm it?
    @PeterUK, I haven't done the speed test with a local file or iperf3. When I've more time, I'll try it.
  • Zyxel_Melen
    I miss that. Without the license, the security services will not work.
    Zyxel Melen
  • Maverick87
    image  Guru Member
    Hi @Zyxel_Melen,
    So without license, I've already "turned off" the security service that consume cpus and memory
  • Maverick87
    image  Guru Member
    Hi @PeterUK, @Zyxel_Melen
    I've tried with iPerf3 and two 2.5Gbit adapters (Sabrent NT-C5GA USB-C — connected to a MacBook and Realtek USB 2.5Gbit Family Controller — connected to a Windows PC via Docking Station).
    This is the result:
    Seems that when the PC receive is always slow, instead when send is always fast
