Zywall keeps blocking my server outgoing traffic
vfm_IT
vfm_IT Posts: 13  Freshman Member
edited April 2021 in Security
I have a server IP:192.168.20.2 in LAN1
Zywall USG110 (Version V4.33(AAPH.0)) keeps block outgoing traffic from that server.
All other PCs on LAN1 don´t have this issue.
I even created a security policy to allow outgoing traffic from my server and I gave that policy priority #1. but It bypass that policy.
I am sharing Log, Policy security and some more.
Please help me.
    PeterUK Posts: 3,892  Guru Member
    Most odd is the gateway for LAN1 192.168.20.1 subnet 255.255.255.0?
    Is their anything more in the logs that might help without the filter?
    Have you made a routing rule from LAN1 to next hop WAN1 by SNAT?
  • imaohw
    imaohw Posts: 124  Ally Member
    First Comment First Answer Friend Collector Seventh Anniversary
    Are you sure the server is on Lan1?
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @vfm_IT
    Can you post the following CLI result for checking.
    Router> show zone user-define
    Router> show zone system-default
  • vfm_IT
    @PeterUK
    Your comment was a great help for me.
    But I can not figure out why the zyxel consider my server 192.168.20.2 is member of LAN2 (see attachment)
    While my LAN1 is 192.168.20.X/255.255.255.0 and my LAN2 is 191.168.X.X/255.255.0.0 (see attachment as a proof)
    I have to create a specific policy rule to make the zyxel allow outgoing access for my server 192.168.20.2 (see attachment as a proof)
    Can someone explain why? is this a bug on the zyxel router?
  • vfm_IT
    @Zyxel_Cooldia
    Hello
    Please find print screen attached
    What port is the server connected too on the USG110?
    How has port role setup?
  • Zyxel_Cooldia
    Hi @vfm_IT
    It seems host 192.168.20.2 goes to wrong interface.
    Can you get the CLI “show arp-table” to check where the host 192.168.20.2 come from?
    Show arp table
  • vfm_IT
    @PeterUK
    Thanks for your help.
    I have been able to identify the issue and fix it.
    My server was connected on LAN2 and that´s why the USG was blocking outgoing traffic from my server.
