About set the DHCP relay on USG40
Hi @Shift
In your scenario, does DHCP server(140.111.111.106) is able ping to USG LAN interface IP address(192.168.100.254)?
If answer is not, then DHCP offer will unable pass to client successfully.
I guess your DHCP server is located on WAN side of USG.
Then you have to add a routing rule on your router.
e.g. Destination: 192.168.100.0/24, NextHop: 140.111.111.11
5
Hi @shift
Welcome to Zyxel community
Does your DHCP server is located in other subnet of USG40? Or other else?
Can you provide the topology of your DHCP environment? (IP subnets/ DHCP server/ DHCP clients…etc)
HI, Stanley:Here is my topolopy of my DHCP enviromentThe DHCP server and USG are at the same subnet...The DHCP client catn't get ip from DHCP server on Windows ServerAny suggestion? Thank you.0
Hi @Shift
5 -
Wa !I think your right, but I will check it later because I got another solution...Thank you again...0
Hi @dpipro
Just Enable “Enable Web Authentication” at “CONFIGURATION > Web Authentication > General tab”, and add Web Authentication policy for Lan users.
Incoming interface : Select the interface on which packets for this policy are received.
Source Address : Select a source address or address group.
Authentication Type : Default-web-portal: the default login page built into the Zyxel Device.
default-user-agreement: The default user agreement page built into the Zyxel Device
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 890 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 203 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
