How to determine hardware version
Hi @jimm,
To determine the hardware version, please check the information below.
GS1200-8
- Firmware code: ABME
- Front panel: no model name is printed
GS1200-8v3
- Firmware code: ACPT
- Front panel: the model name “GS1200-8” is printed on the lower left
However, the firmware version (ABME) suggests that it is a V1 or V2.
Where do you see the firmware version (ABME)?
Zyxel_Judy
Hi @jimm,
GS1200-8
GS1200-8v3
Zyxel_Judy
ignore, please see below
I found the firmware by connecting it to my laptop and browsing to 192.168.1.3. Also, the physical description you provided (reset button present and GS1200-8 absent on the front panel) matches a V2.
I bought it from Amazon who was the shipper but the seller was Zyxel Store. You may want to have a word with Amazon about binning.
Also, the package it came in (see photo) does not look like retail packaging to me. Something is amiss. Back to Amazon it goes.
Also, I won't buy another one from Amazon, since with my luck I'd just get another V2. Very disappointing.
Hi @jimm,
Thanks for sharing this, and for the follow-up details.
If you’d like to be sure you’re getting the GS1200-8 v3 specifically going forward, the official Zyxel resellers/ retail stores are the recommended option.
Retail Stores | Zyxel Networks
One more note: Amazon listings for Zyxel products are often fulfilled by different third-party sellers, even when “Zyxel Store” appears as the seller name, and stock/hardware revisions can vary between them. If you have any concerns, please contact them directly.
Zyxel_Judy
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
