Cant connect to VPN on MAC
Hi @Robert
Welcome to the forum. Make yourself at home.
There are several VPN configurations: PPTP, L2TP, L2TP/IPSEC, IKEv1, IKEv2 ... so it is difficult to help you without more information,
I suggest you to provide your configuration, traces, logs ...
Regards
HI Alfonso
I'm using PPTP configuration, it was working perfectly in both Windows and Mac clients. The Macbooks i have were updated to Mac OS Mojave. I downloaded the Zywall SecuExtender version 1.1.8, since the other version didn't work anymore. Now after configure it correctly the server info etc, it cant connect to the vpn on MAC.
This is the log of the attempt:
State changed to Connecting
2019-07-22 12:21:57: Checking reachability status of connection...
2019-07-22 12:21:57: Connection is reachable. Starting connection attempt.
2019-07-22 12:21:57: Attempting to resolve server address (xxx.xxx.xxx)
2019-07-22 12:21:57: Server address resolved to IPv4 address (xxx.xx.xx.xx)
2019-07-22 12:21:57: Requesting authentication token from client
2019-07-22 12:21:57: No authentication token present, requesting authentication details
2019-07-22 12:22:08: Requesting authentication token from server
2019-07-22 12:22:08: Requesting token from (xxx.xxx.xxx)
2019-07-22 12:22:08: Attempting to establish a connection to the remote server (VPN site):443
2019-07-22 12:22:08: Waiting for reply from remote authentication server
2019-07-22 12:22:38: No reply from remote authentication server
2019-07-22 12:22:38: Authentication attempt aborted
2019-07-22 12:22:38: State changed to Disconnected
Let me know, Thanks
HI Robert additionally you might try the native MacOS VPN client using L2TP over IPSEC . Refer to the System Preferences / Network / + (add a new interface)
Its very straightforward and reliable. (MacOS 10.10..... 10.14) stable if you are using basic L2TP.
This works fine with USG appliances... make sure your phase 1 (VPN Gateway) and phase 2 (Conn) settings are compatible with some iOS devices
HTH
WarwickT
Hong Kong
Hi @Robert
Welcome to Zyxel Community. 😊
Can you post the USG error log as well? It would be helpful to troubleshoot this issue.
Go to “MONITOR > Log > View Log”
Hi @Robert
That’s weird. Windows secure extender is okay, but fail on MAC.
The USG log indicated that user has logged in, but MAC log is “Disconnected”.
I will contact you to troubleshoot it via private message.
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
