Metric overwrite unicast
PeterUK
PeterUK Posts: 4,434 image  Guru Member
edited April 2021 in Security
tested on ZyWALL 110 with V4.33(AAAA.0)ITS-WK19-r88384
This is the config for OPT without unicast or Metric
interface opt
upstream 1048576
downstream 1048576
mtu 1500
type external
ping-check 194.168.4.100 method icmp period 5 timeout 5 fail-tolerance 5
igmp version 2
no ping-check activate
use-defined-mac
mac 00:24:1D:xx:xx:xx
ipv6 enable
ipv6 dhcp6 client
ip proxy-arp 192.168.254.0/24
ipv6 nd ra accept
ip address dhcp
This is the config for OPT with unicast without Metric (after inactivate and activate of OPT)
configure terminal
interface opt
ip address dhcp unicast
interface opt
upstream 1048576
downstream 1048576
mtu 1500
type external
igmp version 2
use-defined-mac
ipv6 enable
ipv6 dhcp6 client
ipv6 nd ra accept
This is the config for OPT with unicast and then Metric set to 2
interface opt
upstream 1048576
downstream 1048576
mtu 1500
type external
igmp version 2
use-defined-mac
ipv6 enable
ipv6 dhcp6 client
ipv6 nd ra accept
ip address dhcp metric 2
  • Zyxel_Cooldia
    Hi @PeterUK
    We appreciate your reporting this issue to us.
    We already identified the issue, so we will fix the issue in the future release.
