Routing between different interfaces / vlan
Hello.
I have kind a strange issue with my Zyxel usg 40. I cannot do routing between different vlans on it.
It must be a configuration issue I am missing.
So I have a router which acts as DHCP - 192.168.1.0 /24
One PC (192.168.1.200) is connected into the router (192.168.1.1). And the WAN port of the Zyxel fw is connected into the router. So all of these are on the same network. PING works fine, including from the PC to the Zyxel fw (192.168.1.50)
On the Zyxel I have created, on LAN 1, a VLAN 6 with gateway 192.168.6.1. And there is as switch befind this interface.
I try to ping from 192.168.1.200 the vlan 6 gateway, 192.168.6.1 and the switch, 192.168.6.2.
But it does not work. I have put rules in place, saying that from WAN I should be able to ping LAN1 and Zywall / LAN1 gateway.
But I do not get any reply.
Any idea why?
Best regards!
Hello.
There is a problem with my router, pointing towards the firewall where vlan 6 is.
I have configured my pc to use the firewall (192.168.1.50) as gateway and it is working now. I have to check that router.
Thank you all for your replies.
Best regards!
I have the same issue with Zyxzl SGB3600.
Have you given your VLAN a zone like VLAN6 and not LAN1?
Or make a firewall rule from LAN1 to LAN1 if zone is LAN1
Hi @alexia_net
In this network topology, the USG looks like run as routing mode. You need to disable snat on USG, and add static on router.
Configuration:
1) Disable “Default SNAT” on “CONFIGURATION > Network > Interface > Trunk > show advanced Settings”
2) Add static route on router.
192.168.6.1 255.255.255.0 to 192.168.1.50
Hello.
Best regards!
@iq test free
Try resetting the Zyxel USG 40 to default settings and configuring it from scratch.0
- 434 Beta Program
- 172 Nebula Ideas
- 406 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 268 Service & License
- 413 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
