Excluding guest wlan from SSL Inspection
Spielkulutur
Spielkulutur Posts: 3 image  Freshman Member
edited April 2021 in Security
our guest-wlan should not be screened by SSL inspection. In the settings I have only found how I can assign the SSL inspection to LAN1 etc. My AP is connected to LAN 1. It sends the normal wifi for the employees and a separate guest-wlan via VLAN. Can I somehow specify that the SSL inspection should not interfere with the VLAN of the guest-wlan or solve it differently? Thanks a lot !
Kind Regards,
Tim Masin
Best Answers
  • Zyxel_Cooldia
    @jasailafan , thanks for sharing.😀
    Hi @Spielkulutur ,
    Welcome to Zyxel community. 😎
    You need to create an address object so that you can select source address on security policy.
    “CONFIGURATION > Object > Address/Geo IP”.
  • Spielkulutur
    Hello jasailafan,
    thanks for your answer !
    I have tried it but the problem is that i can´t choose VLAN in the Pv4 Source.
  • Zyxel_Cooldia
    Hi @Spielkulutur ,
  • Spielkulutur
    Hi Zyxel_Cooldia,
    thank you very much it worked !
