Get a ATP200?
Hi
My USG300 run out of Support and Update and until tomorrow there is a Trade in for a ATP200, 500 action.
Here is no licence available: https://www.zyxel.com/License-Finder.shtml
My IT Distributor show me just: LIC-GOLD-ZZ0001F, LIC-GOLD-ZZ0002F and the arent cheap.
I dont use and need any € Service on my USG. Its just for Home.
Here only the Hotspot Option is interesting to me.
Another think who suck is that thee are just 2 WAN Ports. The USG300 support up to 6 WAN Connection. I will get a DSL + LTE Backup link to the Cable so it would be 3...
For firewall only product with hotspot option you can look at ZyWALL310 or VPN300.
There is no service bundle by default at ZyWALL310 and VPN300. If you just only need Hotspot feature.
Both models are suitable for your scenario.
I am interrested in a feature.
I will make an open and free Wifi Access Point where Guest can surf arround. It possible to select in the USG 310 or AP200 an Option to allow only Homepages who are fall into a categories like: http://www.cyren.com/url-check-iframe
Results for your request:
Full URL: orf.at Categories: News
to use the contend filter as white list?
Yes, you can use white list. If network policy is only specific URL can be access, you need to enable “Allow web traffic for trusted web sites only”
Go to “CONFIGURATION > Security Service > Content Filter > Profile ”
Today it arrive here a way to early but nobody was asking me...
So can I power it up without active the 1Y Licence?
I need to wait until next Year to active because I dont have need to wait for the new L2 Switch.
Nope since since one the ATP's purpose is to protect users from the external threat when deploying the device. The registration and license need to be done in beginning when deploying the device
For example sett the WAN, Config a VPN, Bandwidth Management, Firewall,... dont neet any licence in my USG.
Hi
Since USB Dongle become damn cheap I tried to plug an 32Gb on into my USG for Logfiles but the dont worked.
How about the ATP? Does the Support big Dongle to save a Logfile onto?
The limitation is based on the file system capacity. We didn’t add specific limitations to the USB drive separately. You can connect the USB storage as long as it is one of the file systems: FAT16, FAT32, EXT2, or EXT3. If you use HDD as USB storage, please be aware of the power supply, using Y-cable as external power supply.
- 213 Nebula Ideas
- 557 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
