Excluding guest wlan from SSL Inspection
our guest-wlan should not be screened by SSL inspection. In the settings I have only found how I can assign the SSL inspection to LAN1 etc. My AP is connected to LAN 1. It sends the normal wifi for the employees and a separate guest-wlan via VLAN. Can I somehow specify that the SSL inspection should not interfere with the VLAN of the guest-wlan or solve it differently? Thanks a lot !
Kind Regards,
Tim Masin
Best Answers
Hi Spielkulutur,
If the guest-wlan is vlan created based on lan1 and zone LAN1, try to add a security policy with the source address of vlan and apply CF profile only and no SSL inspection to this security policy rule.
6 -
@jasailafan , thanks for sharing.😀
Hi @Spielkulutur ,
Welcome to Zyxel community. 😎
You need to create an address object so that you can select source address on security policy.
“CONFIGURATION > Object > Address/Geo IP”.
Hi Spielkulutur,
6 -
Hello jasailafan,
thanks for your answer !
I have tried it but the problem is that i can´t choose VLAN in the Pv4 Source.
Hi @Spielkulutur ,
Hi Zyxel_Cooldia,
thank you very much it worked !
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
