Config VPN CLI
IT_Field_Support
IT_Field_Support Posts: 97 image  Ally Member
edited April 2021 in Security
I would like to know the command to change the VPN Peer primary Gateway Address . I need to change the gateway IP on many routers with a script but cannot find the right command in the CLI manual.
Thanks,
Davy
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,568 image  Zyxel Employee
    Hi @IT_Field_Support
    The cli as below,
    configure terminal
    isakmp policy [VPNGateway name]
    peer-ip [Peer primary Gateway Address] 0.0.0.0
    exit
    write
    Let us know if you need any help.😀
  • IT_Field_Support
    Thanks for the answer. With this command I can enter in VPN_connection profile but it is not working for VPN Gateway profile, I have this error when I try to call the VPN Gateway profile :
    % v2 -> v1policy name: vpn_gateway_msfch
    retval = -18006
    ERROR: setting failed!
  • IT_Field_Support
    Okay, this is strange, I did :
    configure terminal
    isakmp policy Test
    It created a new VPNGateway named "test".
    But when I try to call my already setup VPNGateway it failed, but I can call the "test" one without any problem.
  • Zyxel_Cooldia
    edited August 2019
    Can you try it again via SSH access without script? Input CLI one by one.
    Will it have error if you type “isakmp policy vpn_gateway_msfch”
  • IT_Field_Support
    Ok I did all my test with a putty ssh session.
    I still have the error when I try to do :
    “isakmp policy vpn_gateway_msfch"
    I tried to disable the gateway and disable both VPN attached to it and I have the same error
    Router(config)# isakmp policy vpn_gateway_msfch
    % v2 -> v1
    retval = -18006
    Router(config)#
  • Zyxel_Cooldia
    Hi @IT_Field_Support ,
    Just noticed the error message “% v2 -> v1”.
    If VPN tunnel is IKEv2, the CLI is ikev2
    You can try it again with cli below,
    configure terminal
    ikev2 policy [VPNGateway name]
    exit
    write
  • IT_Field_Support
    Perfect !
    Thanks a lot !
