Internal to WAN interface dropping
I have a virtual server setup to provide external services. Everything works when outside the network, but from inside on my private network it goes out to WAN and then gets dropped. What am I missing to allow internal traffic to hit wan? USG60 same set doesn't seem to have a problem. Only ATP200
I figured out a workaround. Created internal DNS A record to go direct to server private IP. Works great. No need to respond.
Hi @iSpeed ,
In this scenario, you need to enable NAT Loopback, it permits the access of a service via the public IP address from inside the local network.
“Configuration > Network > NAT > Virtual Server profile”
Thanks for the response Cooldia. I thought maybe that would do it, but getting an error when selecting. Certain restrictions when using loopback?
Hi @iSpeed
Yes, it have restriction on that. If the virtual server rule external IP is ANY, it’s unable to enable NAT loopback. Because It might cause the device unreachable.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
