VPN IPSec Multicast
GroundOPSADS
GroundOPSADS Posts: 2 image  Freshman Member
edited April 2021 in Security
I have 2 USG60 and configured a VPN IPSec Site to Site with ddns. It works so far.
Now I want to send a Multicast ouver this tunnel. How I've to setup this tunnel?
Thanks a lot!
  • Ian31
    Ian31 Posts: 174 image  Master Member
    USG support IGMP proxy over VTI IPSec VPN tunnel interface.
    But it's limit on what's kind of multicast application you using.
  • Zyxel_Cooldia
    Hi @GroundOPSADS ,
    Welcome to Zyxel Community. 😀
    kindly share more about your scenario/application.
  • GroundOPSADS
    Hello @Zyxel_Cooldia thanks first for your support!
    See the picture.
    I've two networks they are connected by "Site-to-site" VPN thats works perfect.
    But also via this VPN I want to send a multicast stream (225.168.33.0/24) from the 192.168.33.0/24 side to the 192.168.44.0/24 side
  • Zyxel_Cooldia
    Hi @GroundOPSADS ,
    It only can be used in VTI interface, the VTI interface can transmit multicast traffic in a VPN tunnel.
    You need to set up the application scenario from “Site-to-Site” to “VPN Tunnel interface.”.
    Please have a try and kindly share your test result    ?
    VPN tunnel interface at “CONFIGURATION > VPN > IPSec VPN > VPN Connection”
    Create a VTI interface at “CONFIGURATION > Network > Interface > VTI”
