USG 110 - SSL VPN - policy route
David582
David582 Posts: 3  Freshman Member
edited April 2021 in Security
Hello together,
Sorry - I checked so many settings and it is still not working, maybe someone knows what to do.
I want to set up an SSL VPN tunnel. We are already using two IPSec tunnels and L2TP tunnels.
Main problem if the SSL VPN tunnel is - not traffic is coming back!
I checked the default SSL VPN policies, changed them a lot of times - but nothing it working.
Internal router IP: 10.100.100.182/16 (lan1)
Internet net: 10.100.0.0/16
SSL VPN range: 192.168.80.1/24
SSL VPN Gateway: 192.168.80.1
I checked the conntion with Wireshark.
As example, if I try to get access to server 10.100.1.45, port 80 - The packet capture tool/Whireshark is always trying to send the packages (TCP Retransmission).
Source: 192.168.80.1, Destination 10.100.1.45 - TCP Retransmission
Source: 10.100.1.45, Destination 192.168.80.1 - TCP Retransmission
Added policies:
From SSL_VPN to any, Source any, Dest. any, allow
From SSL_VPN to ZyWall, Source any, Dest. any, allow
Added policy routes:
Incoming any, Source SSL VPN Range, Destination any, Next-Hop auto
Incoming any, Source any, Destination SSL VPN Range, Next-Hop auto
I would be very thanksfull if someone has further ideas.
Thanks a lot and best regards
David
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @David582
    Welcome to Zyxel Community. ?
    The SSL VPN Gateway IP address should not within SSL VPN range.
    You can change Network Extension Local IP to default IP 192.168.200.1 and try it again.
    CONFIGURATION > VPN > SSL VPN > Global Setting
  • David582
    edited August 2019
    Hello @Zyxel_Cooldia
    Thanks a lot for your reply!
    I changed the GW - but still not change.
    Tunnel is connecting and I can ping/access the router (local ip 10.100.100.182), but no other server in the local net.
    By the way.. I am using the latest SecuExtender, version 4.03 and
    the latest USG 110 firmware, V4.33(AAPH.0).
    Again, thanks - best regards
    David
    Edit: Picture of log firewall attached.
  • Zyxel_Cooldia
    Hi @David582
    There is no need to add policy route for SSL VPN connection in USG.
    Please delete policy route related to SSL VPN(or subnet 192.168.80.0/24), and try it again.
  • David582
    Oha - I was sure that there is only a "small" problem - but I couldn't find it.
    Thanks for your reply. I deleted all policy route related to SSL VPN. First there was no change - but then I saw that "Use IPv4 Policy Route to Override Direct Route" was activated. I don't know why and I don't know why I did not see that till now. After deactivating the SSL tunnel was able to get access to the local net (10.100.0.0).
    If it is ok for - another small question.
    It would be nice if the SSL VPN tunnel can access some server through a IPSec tunnel (172.30.107.0). For this I need a policy route, correct?! Tried it with:
    SSL VPN --> USG 110 --> IPSec
    Incoming SSL VPN, Source any, Destination IPSec range, Next-Hop IPSec Tunnel.
    Thanks and best regards, have a nice day
    David
  • Zyxel_Cooldia
    edited August 2019
    Hi @David582
    It’s doable. The following configuration guide for your reference.
    How do I allow SecuExtender clients to access servers in the remote site/company through VPN tunnel?
