Nat 1:1
DiGiSoft
DiGiSoft Posts: 6
edited April 2021 in Security
Hi Sir,
I'm using USG40 with 2 VDSL PPOE, wan1 e wan2.
I have create 2 rule NAT 1:1
wan1_ppp -> IP_VDSL1 -> local IP 192.168.1.10 (local server) -> External port 5060 -> Internal port 5060
wan2_ppp -> IP_VDSL2 -> local IP 192.168.1.10 (local server) -> External port 5060 -> Internal port 5060
When I receive cuncurrently packet on wan1 and wan2, local server see external Source port is change.
Can I fix source port for 2 wan to one internal server?
Regards
Alex
    PeterUK Posts: 2,833  Guru Member
    First Anniversary 10 Comments Friend Collector First Answer
    edited August 2019
    The USG40 only has one WAN port and a OPT port are you sure you don't have the USG60?
    What firmware are you on?
  • DiGiSoft
    Yes,
    I have config OPT as wan2
    Firmware version is: V4.33(AALA.0)
    Regards
    So you have traffic like this:
    > IP12.12.12.12 Source port 5060 – WAN1 IP123.123.123.123 local port 5060
    1:1NAT
    > IP12.12.12.12 Source port 5060 -IP192.168.1.10:5060
    > IP12.12.12.12 Source port 5060 – OPT IP45.45.45.45 local port 5060
    1:1NAT
    > IP12.12.12.12 Source port changed -IP192.168.1.10:5060
    Because its to the same server and from the same source port NAT changes the source port I don't think theirs any way round this are you having VoIP issues because of this?
  • DiGiSoft
    DiGiSoft Posts: 6
    edited August 2019
    Hi PeterUK,
    it is strange,
    I can't have 2 different external IPs with the same port on 2 wan inbound with nat 1: 1 on the same server without the external port source changing?
    Trunk VoiP need trust IP and PORT external, Zywall change external source port dynamically.
    Alex
  • DiGiSoft
    DiGiSoft Posts: 6
    edited August 2019
    Can I change external port statically method?
    Alex
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,461  Zyxel Employee
    Hi @DiGiSoft ,
    Welcome to Zyxel Community. ?
    You can enable SIP ALG and try it again.
    BTW, may I know what is your current VoIP phone issue? SIP Phone client cannot register to go on-line?
    Phone can go on-line, but cannot make phone call? or can make phone call, but no voice?
    Enable SIP ALG at “CONFIGURATION > Network > ALG”
  • DiGiSoft
    Hi Zyxel_Cooldia,
    no work with sip ALG,
    ALG replace public ip in sip message, server no accept this.
    My sip server needs to know port and ip source to accept sip messages, I configured trunk in my server (Ip and Port) and only this trunk is enable to accept message.
    Trunk use Ip authentication no User authentication
    Alex
  • DiGiSoft
    No solution found,
    I think my Server plattform no compliant with Zywall.
    I must return my old firewall
    Alex
  • Zyxel_Cooldia
    Hi @DiGiSoft ,
    Can you do the test again and capture packets on USG-40 Wan and Lan interface?
    I would like to see the packet trace.
Security Highlight
