XGS3700-24HP Firmware Update Error
Nurhan_Guler
I get this error when upgrading the xgs3700-24hp firmware.Can you support the solution?
Welcome to Zyxel community.
For starters, firmware upgrading is unique in XGS3700 series, you must go one version at a time, that is, 4.10 -> 4.20 -> 4.30. So if your current version is 4.10, please upgrade it to 4.20 firstly and then 4.30.
Please also check if your .bin file is damaged or not, you may download in the link below:
ftp://ftp.zyxel.com/XGS3700-24HP/firmware/XGS3700-24HP_4.20(AAGD.1)C0.zip
ftp://ftp.zyxel.com/XGS3700-24HP/firmware/XGS3700-24HP_4.30(AAGD.2)C0.zip
Also, it's suggested that you specify the image number which you desired to upgrade.
Hopefully it helps.
Zyxel_Lucious
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
