zywall 1100 for 4 users
adelatorre
Is there any way to get a reduced cost for the secured services for the zywall 1100?
This is my home router and there are only 4 users here.
Hi @adelatorre
If the device only need to serve 4 users, you may consider the entry-level model like USG20-VPN
But the USG20-VPN is likely not as fast then the Zywall 1100
It depends on what kind of application will be used on USG20-VPN. For VPN related applications, yes the throughput will be lower than Zywall1100.
- 441 Beta Program
- 292 Service & License
