VPN IPSec Multicast
I have 2 USG60 and configured a VPN IPSec Site to Site with ddns. It works so far.
Now I want to send a Multicast ouver this tunnel. How I've to setup this tunnel?
Thanks a lot!
USG support IGMP proxy over VTI IPSec VPN tunnel interface.
But it's limit on what's kind of multicast application you using.
Hello @Zyxel_Cooldia thanks first for your support!
See the picture.
I've two networks they are connected by "Site-to-site" VPN thats works perfect.
But also via this VPN I want to send a multicast stream (225.168.33.0/24) from the 192.168.33.0/24 side to the 192.168.44.0/24 side
Hi @GroundOPSADS ,
It only can be used in VTI interface, the VTI interface can transmit multicast traffic in a VPN tunnel.
You need to set up the application scenario from “Site-to-Site” to “VPN Tunnel interface.”.
Please have a try and kindly share your test result ?
VPN tunnel interface at “CONFIGURATION > VPN > IPSec VPN > VPN Connection”
Create a VTI interface at “CONFIGURATION > Network > Interface > VTI”
- 588 USG FLEX H Series
- 477 News and Release
