Comparison between NWA5123 AC-HD and WAC6303D-S ?
Best Answers
The WAC6303D-S has smart antenna incorporated. You could check their components in the overview tap of the links.
Agree that is not clear in their specs page...
"You will never walk along"5 -
Hi @RTH10
Both WAC6303D-S and NWA5123-AC HD APs have good signal quality, performance and coverage.
WAC6303D-S supports smart antenna which is more suitable for high density environment.
The difference is mainly in high density smart antenna technology has better capability for anti-co-channel or adjacent channel interference.
As you mentioned that WAC6303D-S adopts Bluetooth Low Energy (BLE) technology, which enables it work with third-party software to push notifications at shopping malls, chain stores or other public venues.
However, NWA5123-AC HD and WAC6303D-S APs are also 3x3 802.11ac wave 2 MU-MIMO (Multi-User MIMO) with supporting 3G/4G interference immunity capability.
Thanks!
5
Hi @RTH10
Thanks!
5
- 588 USG FLEX H Series
- 476 News and Release
