NWA1123AC: HD vs PRO?
2»
  • Homelab
    Homelab Posts: 21 image  Freshman Member
    OK thanks. Let's assume that I DO have frequent interference from radar; I assume that I can turn off the DFS feature on the AP so it does not waste time/resources trying the DFS channels?
  • RTH10
    RTH10 Posts: 25 image  Freshman Member
    Indeed, you are not compelled to be using the DFS channels at all; actually given that the HD type of AP sports a way stronger 5GHz signal as compared to its non-high density counterpart you may not need to rely on DFS channels at all;
  • Zyxel_Panda
    Zyxel_Panda Posts: 97 image  Zyxel Employee
    Hi @Homelab
    Exactly! DFS channels are optional on the AP, so you can decide whether to use or not with these channels depending on your environment.
    Thanks @RTH10 for the answer.
