GS1920-24 v2 - 802.1x and guest VLAN not working correctly
I have problem to setup "private" and guest VLAN on switch GS1920-24 v2.
What I want to setup:
Port 2 - access port with enabled 802.1x authorization (eap-tls/peap in my case) with default "private" VLAN 10 for authorized user, and guest VLAN 99 for non-authorized user.
What I have try and didn't work:
I. VLAN 10
- "Static VLAN setup" - port 24: fixed, tagged (uplink), port 2: normal, untagged
- "VLAN port setup" - port 2: PVID 10, untag only
II. VLAN 99
III. 802.1X
- Enable (global)
- port 2: Enable
IV. Guest VLAN
- port 2: active, Guest Vlan; 99, Host-mode: Multi-secure, Multi-Secure num: 1
In this setup user (neither authorized nor unauthorized) didn't get IP from DHCP server. I can see DHCP request (on server) but client didn't see DHCP offer.
What I have try and work but with defect:
The same setup but membership of access port 2 was set to "Fixed" for both VLAN (10 and 99). In this case client get the right IP from DHCP server (authorized client get IP from VLAN 10 subnet and unauthorized client get IP from VLAN 99 subnet) and network work correctly. BUT there was a traffic from another VLAN on that port respectively. If a user was authorized, there was a traffic from guest VLAN 99, and unauthorized client can see packet from private VLAN 10.
If I changed the IP address (VLAN 10) on authorized client to address from the guest VLAN subnet (VLAN 99), connection was not working (cannot ping another devices in VLAN 99) (and vice versa), so the PVID was working correctly (ingess).
I thing that the problem is that port is member of both VLAN (fixed) and in that case switch send packets from both VLAN to access port 2 (egress).
Is this behavior ok, or I have wrong configuration?
Thanks for any advice.
Hi @matejp
Welcome to Zyxel community!!
This is a normal behavior for current design due to the port is the member of both VLAN
Therefore, the port will receive the broadcast packet from another VLAN
Best regards,
Zyxel_Derrick
5
Hi @matejp
Best regards,
Zyxel_Derrick
5 -
Thanks for your answer.
But isn't this a security issue? In guest VLAN users can see MAC address from private VLAN, SMB broadcast, etc.
I recently had the same problems on two different GS1900 series switches in which the client devices were not getting IP addresses from the USG devices the switch was connected to (even though the USG was receiving the request and assigning an IP). In both cases, the solution was to complete the VLAN configuration, save the configuration and then reboot the switch. Only AFTER the switch was rebooted would the DHCP packets get delivered to the client devices. The USG did not have to be rebooted, but the switch did - which still meant the VLAN configuration had to happen during non-business hours.
After reading your description, I don't think it is related to 802.1x and it's more likely related to the VLAN mis-configuration and seems like the problem has been resolved?
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
