GS1900-8 trunking?
Stampeder
Stampeder Posts: 14 image  Freshman Member
edited August 2022 in Switch
I have a ubiquiti ap in my barn that is transporting valns 10 and 90. This connects to my GS1900-8 on port 8. Ports 1 through 4 I want to setup on VLAN 90 for my ip cameras and ports 5 thru 7 on VLAN 10. Can you show me how to configure my GS1900 that has software V2.40(AAHH.1)? I know I am missing something in the trunking portion.
Thanks.
Glenn.
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126 image  Zyxel Employee
    edited August 2019
    Hi @Stampeder
    Please follow the steps below:
    1. go to "Configuration > VLAN" to add VLAN 10 and VLAN 90
    2. go to "VLAN Port" and select VLAN ID 90 to configure port 1 to 4 untagged and port 8 tagged
    3. go to "VLAN Port" and select VLAN ID 10 to configure port 5 to 7 untagged and port 8 tagged
    4. go to "Port" configure PVID 90 for port 1 to 4 and PVID 10 for port 5 to 7
    Then you can achieve your setting
    Zyxel_Derrick
  • Stampeder
    Just one more part to my question:
    Should port 8 be set to VLAN trunk enabled and also what about filtering?
    Thanks.
    Glenn.
  • Stampeder
    Thanks very much for the explanations and help.
    Best regards.
    Glenn.
